lookin for the best drivetrain
Old May 16, 2008 | 02:59 PM
MOTORJOHN's Avatar
Default lookin for the best drivetrain
so i have a 67 camaro w/beefy 350, t-5 (i know it sux) and a 12 bolt with what i believe are 4.56 i dont like it of course, i drive my car alot!! so as you can imagine it just isnt street friendly so im trying to see what i can switch the gears with, i also have a muncie-4 crusher that i pulled out of it that im going to probably put back in can anyone help???thanx!!
Old May 16, 2008 | 03:31 PM
t9ojetpilot's Avatar
Default RE: lookin for the best drivetrain
[:@] john not quite sure what all your askin for help on. it sounds like you would like to change the gears in the rear end?? if you have 4.56 ( horrible street gears kinda racy race only) as im sure youve found out, then you must stay in the 4.00 series gears unless you are willing to change carriers also. the carriers 2,3,and 4 series are based on thier respective gear ratios and have different spacing for the gear sizes.
most transmissions both auto and manual usually have a final drive ratio of 1 to 1. this is where tha newer trannies come in handy as some have true overdrive gear ratios and can allow rear end ratios into the 4.00's and still retain some streetability and get a good jump at the stoplight or the strip. ive found 3.73 to be a good all around ratio but its a preference and mileage thing kurt
1augapfel
Feb 28, 2020 12:56 PM
jnghall
Nov 14, 2009 05:04 PM
BenLeedy
Jun 17, 2009 11:04 PM
luvchevys5500
May 29, 2008 07:12 PM
microkid
May 4, 2007 09:39 PM
