long tube headers
Old Jul 30, 2007 | 08:51 PM
8485Chevycowboy's Avatar
Default long tube headers
has anyone put a set of of long tube headers on a 96/97 lt1.... if so how did u run ur exshust with cats??? did u have any problems... pls if anyone has i could use as much info as u can give me... THANKS
[IMG]local://upfiles/4378/E43F2EFC7EA24953A80187C9804B1472.jpg[/IMG]
Old Jul 31, 2007 | 02:01 AM
95slvrZ28's Avatar
Default RE: long tube headers
Mine's not a '96, but that doesn't matter, the only difference if you have 2 O2 sensors after the cats. Anyway, if you get LT headers and are still going to run cats you have to get a catted Y from the manufacture of your headers. This is the exact reason why I went with Kooks, they offerend everything I needed and from what I read quality was extremely high(and it is), they also have the best ground clearance for the LT1 cars(there was an article about a '96 LT1 build from Chevy High Performance where they used Kooks for that very reason). I didn't really run into any issues, it's a bit of a trick to get them on the car(you have to jack the motor), but other than that they're great. I would recomend that you get additional spark plug heat shields, the car came with 3, but you can get more from a GM dealership and with LT headers they're a must so you don't fry those plugs/wires.
Old Aug 1, 2007 | 06:25 AM
Blade's Avatar
June 2007 ROTM
heard some issues about long tubes headers dragging on the ground or hitting.
Fitzs
Jul 25, 2011 07:59 PM
Faalvino
Dec 28, 2010 08:52 PM
SS_2000
LS Series Tech
13
Apr 24, 2010 11:25 AM
rsh3429
Apr 4, 2009 11:12 PM
jbe123
Sep 7, 2007 12:40 AM
