Fuel pressuer regulator?
Old May 13, 2008 | 01:41 PM
damnyanks87's Avatar
Default Fuel pressuer regulator?
I purchased a 1980 camaro a a while ago and am currently in the process of converting a seperate TBI 350 to Carb in order to swap the motor into the camaro. Thus far i have gotten new intake manifold and a new carb, everything else im just taking off the old motor. I have taken the fuel pump from the old motor and other random little things as needed. my question is whether or not i need a fuel pressure regulator or if the fuel pump in the camaro has the pressure pre set. Any help would be grealty appreciated, thanks.
Side note: i have a TH400 trans im putting in in place of the TH350, does anyone know the specs of the new drive shaft i need to get?...thanks again.
Old May 13, 2008 | 03:07 PM
Default RE: Fuel pressuer regulator?
Your TBI FI engine was fed fuel from an electric in-tank mounted pump. Your 1980 used a mechanical engine mounted pump. Does your new engine have provisions for using a mechanical pump? The mounting boss is probably there, but there's a good chance that the block isn't machined through to accept one. If it is, the old mechanical pump will work as it did on the old engine, and a regulator isn't needed. If not, you'll have to install an inline electric pump back by the tank (better to push than pull the fuel). And you won't need a regulator as long as the pump doesn't put out more than in the 5-7 psi range.
Old May 17, 2008 | 12:23 PM
Well the push rod went all the way in (with some force because of the gunk build up) so i would assume that it was machined all the way through....just one more thing to worry about when i start this thing up...thanks for the help
Old May 17, 2008 | 03:35 PM
Can you crank your engine over by hand at the moment? I would do that while pushing up on the pump rod to make sure the rod is moving up and down. I don't know about yours, but a cam designed specifically for an FI engine (electric fuel pump supplied), may not have the lobe on it to drive the mechanical pump.
Old Jun 19, 2008 | 08:31 PM
hobby2's Avatar
Banned
Buy a Ford. You will be a happier person, and suck less.
**Please refer to this link when reading my posts!**
https://camaroforums.com/m_220420/tm.htm
Kendagenius
Feb 5, 2017 12:23 PM
onefastls1
Jan 17, 2013 04:27 AM
98maro
Jun 19, 2012 11:58 AM
numskull223
Nov 2, 2011 10:40 AM
doww301
Jun 15, 2010 05:11 PM
