LT1/LT4 Tech 1993-1997
Fuel regulator
Old Oct 14, 2011 | 09:51 PM
numskull223's Avatar
Default Fuel regulator
My Z has a Holley fuel regulator on it. I believe its dried and not working. It sat for 1 1/2 yrs so I think it my flooding prob. Has anyone ever used a different regulator instead of a LT1 style?
Im considering on buy factory fuel rails and replacing these factory one on my car that are chopped up cause of the NOS, I believe I could have set it up a lot cleaner.
Old Oct 15, 2011 | 01:25 AM
see what tpis has they used to have some pretty good lookin stuff for the lt1
Old Nov 1, 2011 | 10:54 AM
OK, heres is a strang thing...well for me. I got my fuel pressure gauge on, running I have 30lbs. So I decided to adjust it, I had the car running and a I adjusted it to 40lbs. The car totally started flooding worse, smoking at idle and almost cut off. So I adjusted it to 25lbs and it wouldnt run. What the heck?? Is it a stuck injector or 2 or 3.....how can I check those. Or am I over looking something??
I had only of my racing buddies say it could be the way it is since its not supose to be a street car, running rich that is.
Old Nov 1, 2011 | 08:52 PM
it may be the tune.
Old Nov 1, 2011 | 09:45 PM
Originally Posted by craby
it may be the tune.
Is there a way to check the injectors to see if one leaking. But im thinking it would take more than 1 or 2 to be leaking to drop that much pressure?? 36lbs injectors, if that makes a difference..
I may not have it much longer tho....got offered ALOT of cash for it...so if they bring me 9,000$ its gone...lol well see if there offer hold water..
Old Nov 1, 2011 | 10:36 PM
i pulled the rack up and then cycled the pump put some cardboard under the injectors so i could see better if there was fuel.
Old Nov 1, 2011 | 11:22 PM
So unhook electrical plugs off injectors and rremove fuel rails up with injectors and cycle the fuel pump, Correct?
Old Nov 1, 2011 | 11:53 PM
i left the wires and all still hooked up.
Old Nov 2, 2011 | 10:40 AM
Oh ok, im gonna try that. Thanks
Kendagenius
Feb 5, 2017 12:23 PM
onefastls1
Jan 17, 2013 04:27 AM
98maro
Jun 19, 2012 11:58 AM
doww301
Jun 15, 2010 05:11 PM
drumr2790
Dec 22, 2007 04:47 PM
