fuel injector cleaner
Old Nov 15, 2007 | 02:34 PM
Saint_Ali's Avatar
Default RE: fuel injector cleaner
do i have to get the computer tuned if i get bigger injectors ? and will the stock wiring harness work with aftermarket injectors ?
Old Nov 15, 2007 | 06:06 PM
Bigger injectors will do nothing for your car as long as the ones you have are big enough. The PCM will try to adjust for the bigger injectors, but up to a point,beyond that the PCM needs to be tuned.
By the way, if you are going to change just one injector get an OEM part. An unmatched injector can cause driveability problems, that means that the delivery rate, driver coil impedance, and speed must be the same on all injectors.
Old Nov 15, 2007 | 07:03 PM
Saint_Ali's Avatar
yeah i know i was planning on buying a set of 8
Old Nov 19, 2007 | 08:31 PM
Saint_Ali's Avatar
what would it be like if i put 30lb injectors without having it tuned for a while ?
Old Nov 20, 2007 | 08:14 AM
02StanGT's Avatar
It would run rich, as the computer still thinks you have stock ones in.
Old Nov 20, 2007 | 05:56 PM
Saint_Ali's Avatar
ok are the stock size 22 or 24 ?
Old Nov 21, 2007 | 10:53 AM
02StanGT's Avatar
I believe yourswould be24, yes. I think the 3.8s are 22.
Old Nov 21, 2007 | 03:11 PM
Saint_Ali's Avatar
cause i read it was 22 for 93 then 24 for 94-97 but im not sure, ive heard both, and i cant find any 22lb ive only seen 21 and 24
Old Nov 21, 2007 | 03:16 PM
02StanGT's Avatar
You may be right. I forgot you had a '93.
Old Nov 21, 2007 | 03:45 PM
  #20
Saint_Ali's Avatar
does anyone know where to get 22lb ones, ive tried summit,jegs,etc but havent found any
eBay Motors: Used set of 8 Delphi 22 Lb/Hr fuel injectors (item 170139050131 end time Dec-09-07 08:29:06 PST)
would those fit my lt1 ?
Kendagenius
Feb 5, 2017 12:23 PM
v64thgen
Feb 24, 2012 10:54 AM
dbess23
Dec 5, 2007 03:22 PM
johnson3034
May 25, 2007 09:35 PM
KS77
Mar 15, 2007 04:54 PM
