Front turn signal bulb out, flasher out too?
Old Jul 24, 2009 | 11:49 AM
Failed Devices's Avatar
Default Front turn signal bulb out, flasher out too?
Hey guys, my left front turn signal bulb blew out on my 2002 Camaro. I have the bulbs to replace it but one issue I am running into is, how to get to the deaed bulb. I have done lots of searching and have come up with the conclusion that I need to remove the headlight assembly. I can free the headlight assembly from one of the adjustment screws, but there is another adjusment screw towards the fender of the car, at the bottom of the headlight that will not disconnect from the headlight. I did not see any bolts holding the screw onto the headlight. Am I missing something or am I going about this wrong?
I also noticed that inside the car, when you try to engage the turn signal, the arrow on the dash stays a solid green. And the rear turn signal lights up and stays solid, which according to my research could mean my relay/flasher is also out, which I have little idea as to what or where that is.
Old Jul 24, 2009 | 11:53 AM
libertyforall1776's Avatar
If a bulb is out on one side, the dash signal indicator will stay solid green.
Old Jul 25, 2009 | 10:32 AM
Ok, thanks for that. I am still having trouble getting to the bolts holding that lense on. Am I supposed to access them from under the car and removing the plastic shroud underneath the front, or by removing the headlight?
Old Jul 25, 2009 | 10:35 AM
under the car and remove the plastic. then remove light bulb from the backside of the light housing.
hkunz
Oct 23, 2010 07:22 PM
pharoh
Jun 19, 2007 05:12 PM
rastapasta
LS Series Tech
Jan 23, 2007 12:14 AM
bluebike2000
Aug 19, 2006 07:51 PM
jamesjmal
Feb 13, 2006 08:38 PM
