Error code 43 ESC
Old Jul 15, 2006 | 09:07 PM
Braelay's Avatar
Default Error code 43 ESC
That explains it all and for that matter i have no idea what to do. I will do a little research but figure you guys might have run into this problem before. Ill explain what the car does. As soon as i start the car the check engine light comes on since i know whats going i let it run 3-5 minutes and then it dies in idle after warming up of course. Try to restart and it wants to but just wont get to the point unless gas pedal is floored. then it starts and dies immediatly. i pull the error codes and get code 43 ESC (electronic spark control) dont know where to start with this and need a little advice other than pushing it into the backyard and lighting it on fire. j/k
PS. sorry for spelling errors kinda tired and dont want to think right now.
Oh ya its a v6 3.1l too just so that you know
Old Jul 15, 2006 | 10:58 PM
SickSickSick's Avatar
Default RE: Error code 43 ESC
i'm not positive but i believe that code is usually set when you have a bad knock sensor. Sick
Old Jul 16, 2006 | 11:51 PM
MadMikeZ28's Avatar
There is also a square, flat black item that has wires plugged into it. That is the ESC. It gets a signal from the knock sensor. They seem to go bad before the knock sensor. The knock sensor sends its signal only when there is a knock.
Bor3d
Apr 13, 2012 12:59 PM
IRUN13
Feb 18, 2012 07:31 PM
parc0r
Apr 28, 2010 01:01 PM
Mustangfighter96Z28
Nov 1, 2007 07:29 PM
jdubs1813
Aug 4, 2007 07:14 PM
