same thing happened to my grand prix 3.4, check the small vacuum lines near, or around the map sensor, make sure there all plugged in one of mine just popped out i guess.
i just got finshed working on a 96 3.4 and it had the same problem i turned out to be the crank sensor. check spark and injector trigger if you have neither it is the cranck sensor
