Engine shut off question.
Old Dec 27, 2009 | 12:43 PM
Sungeun's Avatar
Default Engine shut off question.
Ok so i just bought my '78 Camaro a couple of days ago. I just rotated the tires because it had a severe pull to the right and the previous owner said it needed an alignment done. Anyway my problem is that every time i accelerate hard the engine will cut off, also when i start it let it run for a couple mins and then go and cut sharply it'll shut off any ideas what keeps doing this? Maybe my battery is starting to die?
Old Dec 27, 2009 | 02:06 PM
What kind of carburetor do you have? It sounds like your float level could be low, making it starve out at higher rpm's and when slamming around a turn.
Old Dec 27, 2009 | 04:27 PM
When it "cuts off" does it catch and run if you let off the throttle quickly? If so, then it is most likely a carb thing. Could also be something simpler like a fuel filter that's not allowing enough flow to keep the bowls full.
Old Dec 27, 2009 | 10:44 PM
Sungeun's Avatar
Not sure about the what type it is, but when i do let off immediately it still cuts off so dunno.
Old Dec 28, 2009 | 01:17 AM
Adam78's Avatar
when u it the gas does it really bog out and sputter and die? thats what my 78 was doing when i first got it and i had a 4bbl Rochester which was all kinds of gunky, a rebuild of that and a new choke fixed the problem right away, all together it was maybe $20 for the rebuild kit and choke, but my real problem was the choke was actually missing lol
Old Dec 28, 2009 | 05:10 PM
Sungeun's Avatar
No it just completely shuts off. No sounds or anything just complete total engine shut off.
Old Dec 28, 2009 | 05:20 PM
Problems while accelerating hard and taking sharp turns makes me think of two things; a fuel supply issue, or a possible loose wire. Check your wiring under the hood for anything loose, like a coil wire, etc. How much gas is in the tank, and is your gas gauge accurate? Any chance you're running on fumes but don't know it. Does it act any differently whether you have a full or low tank?
Old Dec 28, 2009 | 09:27 PM
Sungeun's Avatar
No it acts the same. ill check for loose wiring tomorrow too drunk to check tonight.
Old Dec 29, 2009 | 11:11 AM
Sungeun's Avatar
checked all the wiring, there was no loose wiring all of em are tight so i dunno. i did notice that it only shuts off like that when the engine is cold after its been running awhile it doesn't do it no more.
Old Dec 29, 2009 | 11:18 AM
Alrighty then. Wait till the engine is bone cold, then remove the air cleaner and see if the choke butterfly is closed, or most of the way closed. I have a feeling the choke is either not closed enough, or just not working at all.
