Engine Problem Help...
Old Apr 19, 2009 | 02:57 PM
Dadowhip08's Avatar
Default Engine Problem Help...
Ok I got a 87 Camaro RS Auto. And It hesitate if you give it alot of gas at a stop. Then between 1100 to 1500 rpms it doest it in a way but if you let it go smooth from idle past 1500 punch it then it hesitates but then at like 2200 and up it usally can handle it? Also the shifts are very hard at times and jerky then how it is normally I Have to double check but it has less then 60k miles on it. Mite be a few things But Nothing seemed to work yet so figure I would ask.
Thanks
Old Apr 19, 2009 | 03:09 PM
draggo144's Avatar
have you checked the timing?
Old Apr 20, 2009 | 11:02 AM
Dadowhip08's Avatar
Not yet but i guess thats what i'll check next...
Old Apr 21, 2009 | 05:48 PM
Z28sleeper's Avatar
It probably wouldn't hurt for you to go over the basic mantienence part of it. Change the spark plugs, or at least make sure non are loose or broken, and check the gap on them. Change the fuel filter. Also check if your kick down cable is functioning properly. My 2 cents.
Old Apr 22, 2009 | 11:20 AM
Dadowhip08's Avatar
I replaced the spark plus less then 300miles ago car doesn't get driven at when i did that i did replace the fuel filter. but I'll double check on everything else Thanks
Old Apr 22, 2009 | 05:37 PM
Oil guy's Avatar
ignition sytem, fuel, is it tunned check on that, vacume leak, sometimes the most basic stuff causes this, compression test
HYDRA_SH0CK
Aug 12, 2010 08:15 PM
HYDRA_SH0CK
Aug 12, 2010 11:24 AM
albo1989
Aug 4, 2010 09:49 PM
IZZY1967RS
Jun 15, 2008 11:11 PM
mgalvan
82-92 V8 Tech
May 2, 2008 09:10 PM
