engine problem
Old Aug 4, 2010 | 07:10 PM
albo1989's Avatar
Default engine problem
i have an 89 camaro with an Lt 350 motor. it has a new intake manifold and holly carb. my problem is the temp gauge is reading like 230 degrees while it is just sitting and running good. also i continue to have to add antifreeze. i have stoped running it since this started happening. Could it be a blown head gasket?
Please help thanks
Old Aug 4, 2010 | 07:24 PM
Was it doing that before you changed the manifold??
Old Aug 4, 2010 | 08:19 PM
albo1989's Avatar
yes it was
Old Aug 4, 2010 | 09:49 PM
HAve you performed a compression test to verify the status of the head gaskets?? Is the car blowing a lot whitish smoke that smells like burning antifreeze?? Get a test kit from an auto supply store to check for the presence of combustion gases in the coolant.
HYDRA_SH0CK
Aug 12, 2010 08:15 PM
HYDRA_SH0CK
Aug 12, 2010 11:24 AM
dangerjakeray
Jul 27, 2009 07:25 PM
IZZY1967RS
Jun 15, 2008 11:11 PM
mgalvan
82-92 V8 Tech
May 2, 2008 09:10 PM
