Engine RPM Problem
Old Aug 5, 2010 | 02:38 PM
HYDRA_SH0CK's Avatar
Exclamation Engine RPM Problem
1992 Camaro RS 305ci TBI
60,000 Miles
The issue I am having is very odd...
The engine at Wide Open Throttle (WOT) will not rev past about 3000rpm. I can nurse the throttle up to redline if I do it very carefully and lightly on the peddle.
http://www.youtube.com/watch?v=te9AH2DgqXs
(Video is mirrored, I apologize)
Have replaced the Fuel Filter
Have checked the TPS and MAP with a voltmeter
Idles Good
SOMEONE PLEASE HELP!!
Old Aug 12, 2010 | 12:23 AM
Garey Darrell's Avatar
Hello!
I understand your information and get the fault code retrieved - if it's lean, replace the fuel filter. If the problem continues, have the fuel pressure checked and moreover,plug wires are in bad condition.
Old Aug 12, 2010 | 10:23 AM
Fuel filter has been replaced, and it cant be the plugs or wires, or it would NEVER reach redline. I can be very soft on the gas peddle and ease it to redline. Its just under WOT that I have this problem.
Old Aug 12, 2010 | 11:24 AM
KissMyTush's Avatar
Originally Posted by Garey Darrell
Hello!
Dude, none of those problems would cause this situation that he is having. I'm thinking either TPS sensor or something to do with the intake. I don't know much about the 3rd Gens. I'm a LS1 guy, but that's where I would start. Either TPS Sensor or something else in the intake like MAF or something.
HYDRA_SH0CK
Aug 12, 2010 08:15 PM
albo1989
Aug 4, 2010 09:49 PM
dangerjakeray
Jul 27, 2009 07:25 PM
IZZY1967RS
Jun 15, 2008 11:11 PM
mgalvan
82-92 V8 Tech
May 2, 2008 09:10 PM
