Edelbrock Thunder AVS Carb Problem
Old May 15, 2011 | 10:58 PM
kaguirre579's Avatar
Default Edelbrock Thunder AVS Carb Problem
Having a little bit of trouble with this new carb. I just installed a Edelbrock Thunder AVS 650cfm carb. Engine is a 350. It has a edelbrock performer air gap intake manifold. Ever since I put this carb on... when I hit full throttle from idle it backfires through the carb or sometimes the engine dies. But if I gradually take it up to full throttle then its fine. It does have MSD ignition and distributor with vacuum advance. 1st thing I checked was timing and the timing is ok. I also decided to check to make sure the camshaft timing was ok (the front seal was leaking, so I needed to replace it anyways). Camshaft timing was ok (stock cam). I was wondering if anyone else has had this problem with this carb. When I was running my stock Quadrajet carb this never happened.
ccamaro88
Jan 16, 2010 11:03 AM
maskedman
Jun 2, 2009 05:27 PM
1980_CAMARO
70-81 V8 Tech
Mar 6, 2008 10:58 PM
68ssap
67-69 V8 Tech
Aug 15, 2007 10:37 AM
69RS350
Apr 22, 2007 10:14 PM
