draining battery
Old Feb 3, 2008 | 08:28 PM
69dmz's Avatar
Default RE: draining battery
Took the car to have the altenator checked. The guy said it was missing the connector in the back. So I went back home to look over the chilton manual. I found it and connected it to the back. I came back and that was the problem, and it starts fine without any problems.
Old Feb 3, 2008 | 10:10 PM
I don't think disconnecting a wire will cause a drain?Unless the wire that was disconnected was touching ground, that makes sense. Glad its fixed.
Old Feb 4, 2008 | 11:23 AM
69dmz's Avatar
When the alternator was checked it wasn't charging the battery. When I came back with the connected wire that goes to the voltage regulator then the alternator was charging. Just glad that its fixed. Thanks guys for all the input.
Old Feb 6, 2008 | 12:53 AM
kotty's Avatar
That blinking light is designedto show you that the anti-theft system inyour 1995 GM is active. I have the same light that flashes in my GMC Truck Parts. Maybe,your blinking light drain the battery.
Old Feb 7, 2008 | 12:21 PM
69dmz's Avatar
Kotty, I have a 1969 Camaro. Way different then newer vehicles, and alot better looking too.
libertyforall1776
Feb 24, 2014 02:11 PM
92RS214k
Apr 19, 2011 11:14 PM
HEAVYCHEVYMAYNE.
Jul 1, 2008 06:29 AM
MochaCaliGirl
Mar 22, 2008 02:28 PM
Camaro_Kid
Oct 25, 2007 06:12 PM
