Dash Lights Not Lighting Up
Old Jan 28, 2010 | 12:29 AM
bvans's Avatar
Default Dash Lights Not Lighting Up
Hey guys,
So on my 4 mile drive home, I looked down and my dash lights weren't lit up
Turn signals, tail lights, headlights, interior lights work fine
The dash was just dead
I also have a second tachometer by the windshield that's not lighting up either anymore
I'm going to check the fuse tomorrow when I have more light, but if that's not the problem, I wanted to post something just incase
If it's not the fuse... Whats the problem?
Vehicle - '74 Camaro LT
Old Jan 30, 2010 | 08:52 AM
osduck5's Avatar
dimmer control that controls the brightenness of the dash lights?
Old Jan 30, 2010 | 09:46 AM
check the wires to the aftermarket tach. they could be causing the issue.
Old Feb 4, 2010 | 10:51 AM
bvans's Avatar
bad news, not the fuse.
or the dimmer control
the wires to the tach all seem fine,
where should I go next to diagnose the problem? Pull out the dash?
Old Feb 4, 2010 | 11:00 AM
thats what i would do. if nothing else to look it over for anything and do some testing with the ohm meter
Old Feb 4, 2010 | 12:12 PM
How did you test the dimmer control to see if it's bad, bypass it?
Old Feb 4, 2010 | 02:44 PM
bvans's Avatar
im figurin it still works fine, cuz if i turn it all the way counter clockwise the interior lights still light up
Old Feb 4, 2010 | 05:50 PM
You can't assume that. The dimmer portion illuminates the gauges through resistance. All the way counter-clockwise, when you feel it click, is an on-off switch that works the interior lights. That's a separate operation from the dash lights dimmer part of the switch.
Old Feb 4, 2010 | 06:52 PM
tbl76camaro's Avatar
Mine did the same thing(Speedometer), but one day I saw a bulb hanging down(It lit up when I turned the lights on, but then it blew)... I just left it hangin down there, but one night the gauge lit up. Still working pretty good so far. Maybe yours will do the same thing mine did.
Old Feb 4, 2010 | 07:47 PM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
I'd say the tach and your dash lights share either the same ground or hot source. One of those is most likely the culprit. If it's the hot it's most likely the wire for dash lights has pulled out at the connector on back of headlight switch.
