Cylinder 5 Misfire
Codes said crank sensor and cylinder 5 misfire. replaced the crank sensor. still misfiring. replaced the plug and wire. still misfiring. ran a can of seafoam, still misfiring, but not as bad. it doesn't do it constantly, just enough to keep me irritated. anyone else got ideas?
try a different wire or plug. if the coil is bad, you will have a misfire on the companion cylinder as it is a waste spark system. one bad coil=two misfires. if that doesnt fix it, you could try to replace the coil, but im 90% sure that isnt the issue. did you buy a quality set of wires? i made the mistake of buying the cheaper wire sets, and ive gone through 2 sets in less than 2 years, and i need a third set already. this time im going with msd
Hi, New guy. I was browsing the net for info on this particular matter and came across this. I literally just had the same thing happen to me. Did you ever find the problem and get it fixed completely? I'm about to replace my crank sensor as well.
