Cowl induction hood
Old 08-27-2008 | 03:10 PM
mikes77camaro's Avatar
Default Cowl induction hood
Okay, I tried search without any luck.
My ride is currently torn apart...see new member post/pics. Before I removed the hood itwas working...kind of. The flapper valve only opened with the accelerator mashed to the floor (full throttle). A co-worker who's helping me with the build says it should open gradually as more pedals put into it.
One..is this true?
Two...how is it controlled?
Any help is much appreciated.
Very blurry Pic B4 tear down.
[IMG]local://upfiles/14347/3F348F3F45E340B18DBAB221F557F564.jpg[/IMG]
Old 08-27-2008 | 05:15 PM
MadMikeZ28's Avatar
Default RE: Cowl induction hood
Its either open or closed. Nothing in the middle. There should be a switch on the gas pedal.
Old 08-27-2008 | 05:19 PM
MadMikeZ28's Avatar
Oh but since yours is not original to that car it could have a swicth on the throttle linkage but still is just open or closed
Old 08-28-2008 | 12:25 AM
The original ducted hood (cowl induction) first came out on the 69 Camaro. A switch would get pushed in by the throttle linkage which then powered a solenoid on the hood which then opened the flapper valve. It's supposed to open fully at 90% throttle (not gradually) which is pretty darn close to "mashed to the floor".
Read all about it: Camaro Super Scoop
Old 08-28-2008 | 01:04 AM
MadMikeZ28's Avatar
The scoop in the picture is from a 80-81 Z28 and if memory serves me on my dads 81 it had the switch on the gas pedal. I put one on my 91 but am too lazy to hook it up to work! [&o]
Old 08-28-2008 | 02:07 AM
That's true, that vintage model had the switch by the pedal. If it were my car, and summer only driven, I would just wire the damn thing open anyway and say screw the mechanism.
Old 08-28-2008 | 07:13 AM
Cool. Thanks for the feed back. It does appear to be a proximity switch on the pedal. I kinda like the idea of having it open full time while driving but would like to have the option of closing it if needed. What do you think of a toggle switch to select open/closed?
Old 08-28-2008 | 02:32 PM
I would want to have control of it too, to open it more often than just with the "heel to the steel".
A toggle switch is a good idea. I would leave it open all the time (weather permitting) to help alleviate under-hood heat. You could then keep it closed if needed in a heavy rain or cold weather.
coylebailey
09-27-2011 06:57 AM
Swiss
67-69 V8 Tech
08-16-2010 01:50 PM
68ssmaro
67-69 V8 Tech
03-01-2010 05:33 PM
freaky
82-92 V8 Tech
02-06-2010 08:30 PM
bd92rs
01-11-2010 11:46 AM
Quick Reply: Cowl induction hood
