Code Reader
Old May 25, 2007 | 07:28 PM
  #21
MadMikeZ28's Avatar
Default RE: Code Reader
It will repeat each code 3 times THEN move on to the next code and repeat it 3 times. So if it came on and flashed ones, pause , flash two times that is the code 12. Watch it do that 3 times total. Then watch for a different set of flashes. If it flashes the 12 again then there are no codes. It is just starting over. So keep watching and counting.
Old May 25, 2007 | 07:48 PM
  #22
Celticsfan's Avatar
so it will do code 12, 3 times, ill go check
Old May 25, 2007 | 08:04 PM
  #23
Celticsfan's Avatar
thats what i get after the 3rd set of 12, looks the same, I KNOW the code went on a few weeks ago but i dunno.
**** cant post it here
heres the vid
http://s11.photobucket.com/albums/a1...525072058.flv]
Old May 25, 2007 | 11:48 PM
  #24
MadMikeZ28's Avatar
Well that was code 12 in the video. And it did that 3 times then continued with code 12 the fourth time? If the car still runs fine then drive it till you can have a shop hook a scanner to it. Use your mineke coupon. If they scan it and dont find anything tell them it comes on while driving. They may try to figure it out to upsell. When they figure it out thats when you leave
Old May 26, 2007 | 01:53 AM
  #25
Celticsfan's Avatar
you think they will have the obd1? I figured that they only had newer, i probably should just call that would solve it...
Old May 26, 2007 | 02:23 PM
  #26
MadMikeZ28's Avatar
They most likely would have a scanner that will do both obd1 and 2. A scanner is a must have in a shop. My Snap-on modis does both
killawatt
Mar 28, 2010 08:02 PM
hevymetalg
Oct 14, 2008 12:08 AM
hevymetalg
Sep 28, 2008 07:50 PM
jfresh
Sep 1, 2008 06:44 PM
350rs
Jul 12, 2007 03:50 PM
