C-clip in posi/LSD stuck!!! Help!!!!
Hey guys, I'm tryin to pull the center section and I got the passenger side c-clip off no problem but the driver side won't come off? I beat the on the hub side to try and push it all the way in but it's just not enough. Any ideas? Oh! And the gear the axle is going thru move with it, like in and out so it won't allow the little bit of clearance I need. Thanks.
Is yours a manual trans? Having a habit of dumping the clutch can contribute to beat up axles.
Yeah the splines on just the driver side axle was slightly twisted. I have the 98 v6 camaro with cai, 3000 stall converter, transgo-HD2 shift kit (a-4) on car adj. Panhard bar and 32mm front sway bar with poly bushing all the way around except for the rear lca.
