Bleeding Coolant?
Old Apr 30, 2008 | 11:18 PM
t9ojetpilot's Avatar
Default RE: Bleeding Coolant?
specter not sure who your directing the "thermostat not on the radiator " at but im failing to find that statements relevence here since no one has made any mention of a thermostat being on the radiator. can ya help us out and clarify the relevence kurt
Old Apr 30, 2008 | 11:39 PM
SpecterGT260's Avatar
Ninja Administrator
i was mostly saying you wont get it to bleed on the thermostat housing. i think [&:]. the way i read it it sounded like you said your tstat is on ur radiator. and you would use this to bleed air and fill the radiator completely.
i know some high end race radiators have a bleed opposite the fill. a cold start up with the cap off and refilling as the water gets pulled through the system is just fine in this case
Old May 1, 2008 | 12:17 AM
[&:] nope nope there are brass air bleeder valves on my heater hose and on the thermostat housing (which is on the water pump). a common set up for vehicles with radiators that sit lower than the engine or have pressurized reservoirs at about the same level as the coolant passages on the engine kurt
djsquare1
Aug 28, 2013 10:38 AM
NoSoupForYou83
Feb 20, 2013 08:57 AM
juice+
Oct 13, 2012 07:13 AM
AnalyzeFaith
Dec 5, 2010 05:54 PM
BasicConcepts
Mar 16, 2010 09:59 AM
