Bleeding Coolant?
Old Apr 28, 2008 | 06:52 PM
Slick6's Avatar
Default Bleeding Coolant?
Do I need to bleed the coolant when I fill it? I just flushed the whole thing so I'm starting over fresh...
Old Apr 28, 2008 | 06:54 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: Bleeding Coolant?
just flush it. leave the cap open and run it up to temp right after filling it because you wont get it full right away. some high end radiators have bleeders, but the stock ones are just kind of a pain. any air will get circulated thorugh and you can keep topping off the radiator, should only take a few minutes
Old Apr 28, 2008 | 07:50 PM
Slick6's Avatar
k, thx spec
Old Apr 28, 2008 | 08:18 PM
Ninja Administrator
dude, didnt u post a pic of ur coolant in another thread? the v6 guys wanna know if their coolant is normal and i swear u had a pic somewhere i just cant find it
Old Apr 28, 2008 | 09:19 PM
Slick6's Avatar
Yeah it's in "Consuming Oil"
Old Apr 29, 2008 | 12:24 AM
t9ojetpilot's Avatar
unless i smoked my breakfast there should be one or two air bleeds in the system. these cars get HOT before fans come one so you really want to avoid hot spots caused by air in the system and boiling. check for and use these, burp the system, start car momentarily then burp again kurt
Old Apr 29, 2008 | 10:35 AM
Ninja Administrator
like i said, mine was when i had completely drained the system, so the pump was sucking in fluid and spitting air back out. from what ive seen you do any burping through the top cap tho, right?
also, on my radiator there was only a single drain on the bottom on the same side as the fill cap.
Old Apr 29, 2008 | 08:41 PM
Slick6's Avatar
ORIGINAL: SpecterGT260
Correct, I got a little burping I guess. As first it didnt want to put out much heat from the heater and my pilar guage was closing on 210... I dont trust the one on the cluster too much, it doesnt seem to accurate. I let it idle a lil longer and everything is good now.
Old Apr 29, 2008 | 10:19 PM
[8D] whew nope my breakfast was a more solid than i thought!! my 95 has at least two air bleeds in the system. one on the thermostat housing and one in the heater hose. really recommend bleeding the air before startup and during initial fireup when doing drain and fills to avoid problems. of course ls1's may be different but id look for them as they put them in place for a reason kurt
Old Apr 29, 2008 | 10:24 PM
Ninja Administrator
our thermostat isnt on the radiator . mine is right on the water pump. later ls1's had it somewhere else tho..... not sure exactly where,
