Best Fix-A-Leak Brand?
Old Feb 9, 2008 | 08:47 PM
mattz28red's Avatar
Default Best Fix-A-Leak Brand?
Ive got some leaks in my camaro, and i wanted to know if anybody knows which brand works the best or if they work at all. I figured insted of getting new gaskets id give this a shot.
Old Feb 9, 2008 | 10:55 PM
CIN's Avatar
CIN
Default RE: Best Fix-A-Leak Brand?
what kind of leaks?
Old Feb 10, 2008 | 01:37 AM
t9ojetpilot's Avatar
[&:] matt pleeeeeeeaaassseee dont do this for cooling systems magic in a can may be great in an emergency situation it does you no favors in the long term. it may fill some voids that are helpful but can also fill the holes you dont want filled. may contribute to electrolasis(sp) and just plain makes a mess of the cooling system. if its oil leaks you speak of anything available is a waste of money this option is truly only a band aid how about we fix the problem instead as you will have to eventually anyway kurt
Old Feb 10, 2008 | 07:26 AM
blackz87's Avatar
Find the leak and repair it. The bandaid approach dose not work.
Old Feb 12, 2008 | 07:24 PM
mattz28red's Avatar
Well i was looking at the ones that you add to your fluids, but i was wondering if you guys knew what brand works the best. The guys who changed my oil said my front seal and my rear main seal were leaking. If you guys have any specific brand you would recoment let me know.
Old Feb 12, 2008 | 09:05 PM
98SS#689's Avatar
In my experiences, none work as advertised and just make a bad situation worse. Like the others have said, fix the problem, don't try to cover it up.
Old Feb 12, 2008 | 09:38 PM
You are talking oil leaks. t9ojetpilotis talking coolant leak. Either way you do not want use the additive. Oil additives that "stop" leaks do it by intruducing a chemical that attack the seals and makes then swell. It can work for a short while but in the best conditions it will speed up the major failure of the seal one of two ways. One way is the seals swell too large and completely rips apart causing the engine to pump all your oil out very quickly. Two it swells to the right size and dry rots 6 months later cause it can not handle the chemical long term. If you have minor leaks, let them leak. Wait till you can fix them right. Chances are they will give at few weeks notice before they go completely in the form of big puddles. Put that additive you could be doing a major repair within a month. Another thing, as engines get more and more hours on them the amount of blow by increase. Once it over powers the PVC system it will push out some oil the easiest place it can. what I am saying is if it is a small leak on a car with a lot of miles there may be nothing wrong with the seal.
I have heard the story too many time. I just had a small leak in the rear main so I put in XYZ additive and 2 weeks later the front seal blow out. Funnypart was several of those cars had rope seals for the rearmains and this stuff has no effect on a rope seal LOL.
Old Feb 13, 2008 | 10:46 AM
williesrepair's Avatar
None work.
Band aid on a gunshot wound is all they are.
Jelz28
Jul 18, 2012 06:01 PM
robmnrd
Jul 7, 2008 01:40 PM
Lill
Apr 15, 2008 05:04 PM
evolution1
Dec 4, 2006 07:33 PM
92 Cobra Charmer
Jun 8, 2005 09:17 PM
