68 Camaro-Fuel Gauge Issue-HELP!
Old Feb 16, 2008 | 02:21 PM
CamaroMan52's Avatar
Default 68 Camaro-Fuel Gauge Issue-HELP!
I will try to explain this step by step.
Fuel gauge was fine until I changed from an automatic to a 4 speed tranny, but at the same time I replaced the speedo cable so the cluster had to come out too.
I checked and re-checked all grounds and everything is the way it was before. I know my father in law had to disconnect "some" wires that controlled backup lights but he didn't mess with the fuel gauge.
Here is what happens. If I disconnect the ground wire that controls the cluster, the fuel gauge USED to drop to "E".
Now if I disconnect the ground wire, the fuel gauge remains at 1/2 tank even though it is full.
OK, If I turn on my headlights while the ground wire is disconnected, the fuel gauge drops to "E", but once I re-connect the ground, the gauge goes back to 1/2.
Can anybody make heads or tails of this??
Thanks!!!
camaro396
Aug 9, 2015 06:29 AM
JennROCKS81
May 22, 2013 10:01 AM
pritchr1
May 25, 2011 07:54 PM
Roscoep
Apr 1, 2011 02:03 PM
vzfox
Nov 10, 2007 10:05 PM
