Bad idle can you help please!!
Old Aug 24, 2009 | 12:15 AM
sscamaross's Avatar
Default Bad idle can you help please!!
Hi,
Im in need of some help. i just purchased a 94 camaro z28 with the lt1. When i went to go pick this car up it idled funny whenever i was sitting at a stop with the car in drive.The guy i told me it needed new plugs. So i bought the car and purchased new plugs for it and it didnt fix the problem, tho it did seem to make the issue a bit better. I was reading more about bad idling on here and most people said to replace the IAC or to take it out and clean it, so i took it out and cleaned it, but didnt help. i was wondering if i need to go buy a new one or if its something else? I also read it might be a vacuum leak. My car only seems to do this really hard idle after it warms up for a few minutes and its only when im at a complete stop,(if im to put the car in nutreal when its doing it it idles fine). The RPMs stay at a bout 700 when its idleing hard and when its idleing fine. The car doesnt always do it either. Will replaceing the wires too maybe help? I really need some help can anyone give me any imput.... thanks a lot
Old Aug 24, 2009 | 01:11 AM
double post. try not to do it. u will be jumping back and forth. helps everyone if all the info on the issue is in one thread.
Old Aug 24, 2009 | 08:19 AM
blackz87's Avatar
I would still lean toward the IAC valve, replace it ($38) and reset the Idle. I would also disconnect the battery to have the EMC go into relearn mode for this change. If this dose not solve the problem then go looking for a vacuum leak before spending money replacing parts.
r00tk1ll
Feb 6, 2015 10:25 PM
Rustyshackleford1911
Dec 27, 2014 09:32 AM
millspec96ss
Dec 12, 2009 10:47 AM
92rs_guy
Apr 9, 2009 11:20 PM
6v49der
Jan 3, 2007 01:51 AM
