abs pump master cylinder
Old Apr 29, 2007 | 01:33 PM
nolahardheadn7's Avatar
Default abs pump master cylinder
Hows it going guys I have a problem and need help. I am changing out my master cylinder and abs pump on my 96 Camaro 3.8l V6 I need to know all the necessary tools that I would need to do this job right and also I heard that I would need to prime the master cylinder if anyone has any know how on that or any tips and know how on how to do this whole job with my brake system I would appreciate your feedback thanks
Old Apr 29, 2007 | 02:14 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: abs pump master cylinder
Wow. Welcome to the forums. You are asking a question that is somewhat extensive to answer. You will need no special tools, I have a vacume pump (brake line bleeder) so I am able to do the job by myself. Priming the master cylinder is nothing more than ensuring there is brake fluid in the reservior and that you have 'pumped' it at fluid seeps out where it should. Priming it comes after you bench bleed it. Why are you doing a job like this on your car? has it sat for a while or did a shop tell you it needed to be done?
Old Apr 29, 2007 | 09:52 PM
My Mothers husband trying to help/learn on how to change brake pads on his car I was bleedeing my brakes along with changing the pads. Well instead of putting brake fluid he put power steering fluid in my reservoir wich messed up the rubber parts in my master cylinder and abs pump. I didn't notice what he did till I started loosing pressure in my brake pedal about 2 months later looked into the problem and found out that what was supposed to be brake fluid in my lines was realy power steering fluid. So as of now I am the laughing stock of the shop.[:@]
Old Apr 30, 2007 | 10:37 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
mmmmmm that will happen. If you dont already have one I would get a chiltons and look in there for more in depth procedures on the brakes. Plus they have pictures.
SS68
Mar 12, 2014 10:45 AM
brian383
Aug 4, 2010 09:57 PM
hkunz
Oct 15, 2009 08:13 PM
kstoll99
Sep 12, 2009 12:08 AM
APSASM
Apr 4, 2009 09:23 PM
