95 camaro turn signals
Old Jun 15, 2010 | 07:25 PM
fastracautomotive12's Avatar
Default 95 camaro turn signals
I have replaced the turn signal switch, flasher under the dash, and checked the fuses. The emergency flashers and brake lights work fine without fail, However i have no turn signals. No flashing lights on the dash or lights on the rear or front. Any suggestions where i should go from here?
Old Jun 17, 2010 | 07:09 PM
osduck5's Avatar
Do you have a voltmeter? check to see if you have voltage at the flasher, I think there are 2 flashers, one for the turn signals and one for the emergency flashers. Are you sure you replaced the right one? If so, sounds like you may have to check for a broken wire.
ayagle
Jul 21, 2010 12:54 PM
WIspartan1026
May 11, 2010 10:47 AM
big wrench
Apr 8, 2009 09:55 AM
Lilspleen
Oct 7, 2008 09:28 PM
