turn signals
Old Oct 3, 2008 | 09:44 AM
Lilspleen's Avatar
Default turn signals
right turn signal arrow on dash isn't blinking. but it is a solid arrow though
Old Oct 3, 2008 | 10:00 AM
MusicMan's Avatar
The Jazz Man
Default RE: turn signals
Are the front and rear blinkers outside the car working? If they aren't, sounds like a flasher relay to me. It's a very easy to fix and cheap part.
Old Oct 3, 2008 | 12:50 PM
02StanGT's Avatar
If a bulb is out, it will do that. Check the bulbs. If that doesn't work, try a new flasher. Before you ask how to check if the bulbs work, I will tell you... Turn the hazards on, then check all bulbs blinking.
Old Oct 3, 2008 | 01:10 PM
Lilspleen's Avatar
i checked the bulbs and i think its the relay
Old Oct 7, 2008 | 08:05 PM
dletner's Avatar
i had the same problem. the flasher is to the right of the steering column. you must take the cover off its kinda hard to find, but you should find it clipped to the right side, almost level with your ash tray.
Old Oct 7, 2008 | 09:28 PM
02StanGT's Avatar
If it is working for the left side (which he made it sound like) he can turn that blinker on, and find the sound to locate it.
ayagle
Jul 21, 2010 12:54 PM
WIspartan1026
May 11, 2010 10:47 AM
z28-94
May 24, 2009 03:15 AM
BAV
Mar 9, 2009 02:18 PM
got3ofem
Jul 18, 2007 04:47 PM
