91 rs camaro Idle probs
Old Jul 30, 2005 | 02:41 AM
volcomchk06's Avatar
Default 91 rs camaro Idle probs
Alright so currently i have a 1991 RS Camaro V6. i am just stumped 100% on whats going on with it. so ive turned to you guys for some help:
When im driving normal my car is fine, but when i get to like a stop sign/stop light the idle gets really low and it drops to like 950RPMS, my mirrors shake.. you get the idea. I dont think this is normal.... i dont like it has to due with the engine like a timing belt or anytthing like that...
anyways some help would be appricated!
thanks
-jamie
Old Aug 8, 2005 | 11:11 PM
Default RE: 91 rs camaro Idle probs
Ok Jamie, relax. Your car does not use a timing belt. Most likely you have an ignition problem. change plugs & wires an see what happens. If still NG go after the coils & the ignition module under them. Are you getting a "check engine lite"? If so see what the code is.
Old Aug 8, 2005 | 11:22 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
could just be some bad gas...
Old May 24, 2006 | 01:40 PM
MoreLikePALcohol's Avatar
Try replacing your throttle position sensor...I had the same problem, worked like a charm for me, plus its really easy...2 bolts, and a plug in
draggo144
Sep 13, 2011 11:01 AM
Rhinohillman09
Mar 9, 2010 04:49 PM
Berlinettaguy_84
May 19, 2009 03:36 PM
sm515
Apr 26, 2009 06:27 PM
weman098
Dec 20, 2008 01:06 AM
