87 IROC No tach
Old Jul 4, 2008 | 03:03 PM
shortyroc59's Avatar
Default 87 IROC No tach
87, 305 tune port IROC, tach stopped working. New tach, module, and coil. Checked the voltage coming off the coil and the distributor and seems to be fine. Any suggestions from here.
Thanks, Shortyroc59
Old Jul 4, 2008 | 04:57 PM
MadMikeZ28's Avatar
Default RE: 87 IROC No tach
There is not much to it. A power wire that also sends power to other gauges so if they work then that should be fine. Ground wire which also supplies other gauges and a white wire from the coil which is the signal wire. Posible the plug on the coil went bad. Sopme times the wires are bent real bad and may eventualy get a short in them.
Old Jul 11, 2008 | 08:52 AM
Thanks for the info. I think it's my remote starter thats' cutting out the tach because everything else is new and when I bypassthe ignition systemand take the tach out of the car and wire it directly it does work.
Old Jul 11, 2008 | 04:45 PM
MadMikeZ28's Avatar
good posiblity
bohuntr
Oct 4, 2014 07:58 PM
gaskincrew
82-92 V8 Tech
May 10, 2009 04:04 PM
94z28chevy
Feb 1, 2009 04:50 PM
oneals camaro
82-92 V8 Tech
Apr 27, 2008 01:11 AM
Andross
Apr 3, 2007 05:04 AM
