700R4 does not go into park!!!!
Old Jul 23, 2007 | 09:59 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default 700R4 does not go into park!!!!
i need help with my car. 86 z28, tpi engine, 700r4 tranny. i noticed the last week that it had some problems going into park. now, it doesnt at all. the shifter is going into parking and staying in place, but the actual tranny does not. it will roll forward, or stay in reverse. wheres the linkage and how do i adjust it? there is one reason why i think its doing it. a few months ago, it stalled about 5 mph and i had no brakes and i put it into park to try to stop it, and all it did was make a loud clicking noise, but not a grinding noise.
Old Jul 23, 2007 | 01:51 PM
Default RE: 700R4 does not go into park!!!!
Sticking the transmission in Park while the car is in motion is bad thing, the shock of the parking pawl suddenly engaging can break things. Being that all other gear positions work, the linkage appears to be properly set. I suspect a damaged parking pawl or detent lever. Have someone move the stick around while you take a look underneath, all that stuff is on the left side of the tranni.
Old Jul 23, 2007 | 02:52 PM
Celticsfan's Avatar
mine does something similar ill stop and throw it into park but it will roll, learned this the hard way last yr...rolled right into a big cement thing at the gas station...but now i just use the e break too
Old Jul 24, 2007 | 07:05 AM
microkid's Avatar
March 2011 ROTM
Technical User
well, now its progressed more. upshifting is hard, downshifting is easy, and its loose when i keep it in gear.
Old Jul 25, 2007 | 08:26 AM
blue_iroc_z28's Avatar
i am having the same park problem , my car will not go in to park , once you start the car its in reverse but the shift indicate says park but i also don't have 1st like the shifter does not go back that far so something is wrong my dad was helping me with thisand he said that the adjustment was bottomed out (dont know which way?) this would not bother me but i dont have a parking brake to hold me still . can some one help?
1986 iroc z28
Old Jul 25, 2007 | 09:48 AM
I suggest you take a ride to a reputable transmission shop and have them diagnose the problem, and at least avoid having to be towed. You want to prevent further damage and avoid having to go for a complete rebuild.
carmel73
May 17, 2014 09:00 AM
Chevymayhem
Mar 2, 2012 11:12 AM
valeo29
LS Series Tech
Nov 11, 2009 03:27 PM
Detector
Mar 24, 2008 04:58 PM
Furr1970
Dec 23, 2007 01:17 PM
