69 Floor pan
Old Jan 23, 2011 | 04:11 PM
Rose350's Avatar
Default 69 Floor pan
does anyone know how heavy the entire floor pan is on a 69 camaro, also what material its made of? I was thinking i could save some weight (if it's steel) by remaking it with aluminum, which is 1/3 the weight
Old Jan 25, 2011 | 09:22 AM
Squid's Avatar
it's steel but remaking it with aluminum reduces the strength it imparts.....by the time you pull and reinforce the area to swap it to aluminum you will end up adding weight.
if you want to lower the weight on the camaro....remove the trunk pan and replace it with aluminum and replace the entire front clip with a fiberglass one.
Old Jan 26, 2011 | 07:30 AM
Rose350's Avatar
thanks, i'll try that
reidski182
Oct 20, 2012 10:30 PM
thebandit110
May 24, 2009 05:09 PM
Kasnooze50
Feb 11, 2009 03:35 PM
red star
Feb 5, 2009 12:57 PM
77Camaro
Dec 13, 2006 05:48 PM
