2000 slp ss camaro
Old Nov 24, 2007 | 11:06 PM
850068camaro's Avatar
Default 2000 slp ss camaro
I just got this car a couple weeks ago,and now whenyou get onit, it feels like ithops &the rear is bounching a little-tis hard to explain..could it be a tranny mount??How do you use the ASR button & fan switch??Any infor would be helpful-Thanks!
Old Nov 25, 2007 | 12:14 AM
SpecterGT260's Avatar
Ninja Administrator
Default RE: 2000 slp ss camaro
i think you are probably just describing wheel hop. happens when youre tires are sticky enough to lift the rear off the ground. you get on it and the back end bounces. its hard on the rear end and should be avoided
Old Nov 25, 2007 | 11:23 AM
th3po1son's Avatar
tires are sticky enough to make the rear end bounce? I dont get it
Old Nov 25, 2007 | 02:43 PM
t9ojetpilot's Avatar
[&:] by "gettin on it " do you mean trying to do a burn out or just accelerating down the on ramp. poison--- specter is talking about wheel hop which is a condition where the tire gets traction but then loses it, usually due to suspension and tire grip which causes a fairly violent thumping or shudder in the rear of the car kurt
Old Nov 25, 2007 | 04:13 PM
its pretty much just when i accelerate fast-but what you said explains it right.Thanks![&:]Do you happen to know anything about the ASR switch?
Old Nov 25, 2007 | 05:53 PM
[&:] the acceleration slip regulation button is basicly the same as traction control(possibly a more familiar term thats getting pretty common) it uses the abs system to brake the wheel with limited traction forcing the other side to (supposedly and hopefully with more traction) to become the drive wheel. dont know that it has any real plusses or minuses for the normal driver except does help in traction limited situations. for us hot rodders it might be considered a less desirable option than a posi or locker for the rear end. i havent seen any head to head comparisons between a posi equipped and an asr equipped car but id venture to guess that all else being equal id think the posi equipped car would accelerate a little faster in a drag race( anyone have some input here) kurt
coopdc78
LS Series Tech
Jun 19, 2010 12:28 PM
hermine2000
2010+ V6 Tech
Mar 22, 2010 02:56 PM
TwistedEdge
Oct 2, 2008 02:00 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
chevy_man
Jun 25, 2007 08:56 PM
