1997 Camaro Misses in 4th & 5th gear
RE: 1997 Camaro Misses in 4th & 5th gear
Well if one of the two you have is a 81 camaro69 I may have to see about changing the way you sway
But Iwant to see pics of the 81 also. My dad had a charcoal with silver interior one.
[&:] not a big fan of anything magic in a can. motorvac or other injector cleaner that is performed in a shop is the only thing ive seen truly help. this is a closed loop fuel substitute that the engine is run on for some time and cleans the injectors, short of this helping the problem injector rebuild or replacement is the next step. a well equipped shop should be able to do this as well as tell through injector flow and pressure tests and ignition patterns on the car, if the injectors are the problem cleaning should be $100 +- kurt
With Techron (make sure to get the stuff especially made for injector cleaning) try doubling the recommended amount as it will work faster, and it won't damage anything, except your wallet.
