1992 camarors
Im trying to put a 1968 350 from a 1 ton pick up, in my 1992 camaro rs . I want to make it carb motor how is the easy way to do the wireing. I had someone tell me i cant use the same wireing because the ignition has the chip in the key . I only want a alternator and a power steering pump that is it. Can i use the same dist. I was wondering if there is a easy way to wire it if I am not useing all that other stuff. please help this is my first time working on a car like this, cant afford to have someone else do it. thanks guys
