1985 camaro z28 help
Old 10-31-2011 | 02:41 AM
travis.joeris's Avatar
Default 1985 camaro z28 help
hi, i have a 1985 camaro z28 it starts and runs (poorly) and when given gas it bogs and studders where should i start
Old 11-04-2011 | 04:18 PM
LT1RUNNER's Avatar
First has this car been sitting awhile or is this a daily driver? Seeing how you haven't given up much info I'll give you this. Start with a tune up and check your timing. let us know how that works.
Old 11-05-2011 | 09:03 AM
im replacing the fuel pump, replaced the fuel filter, spark plug and wires, if i have to mess with timing i get help cause i have no clue about that. and it has been sitting for awhile
Old 11-07-2011 | 02:34 PM
LT1RUNNER's Avatar
Before you replace the fuel pump do a fuel compression test first. That's alot of work to do and if the fuel pump is good then it's all for nothing. Take it to a car guy to check the timeing. Should only take a few minutes,
My85Camaro
11-12-2011 10:41 PM
usaf1989
12-27-2010 09:05 PM
cwolfc
04-29-2009 07:33 AM
jml317
82-92 V8 Tech
12-12-2007 08:48 AM
