1979 Camaro HELP!
Old Jul 15, 2008 | 09:40 AM
stilllearnin's Avatar
Default 1979 Camaro HELP!
So I recently purchased a '79 Camaro Ralleysport, beautiful car! Has a new 350 I put in that only has about 3500 miles on it, so very new. Recently I replaced all the spark plugs and wiring because it was running really rich and some of the cords were cracking. When I took the plugs off they were covered in burned black oil so I know I have a problem with my carb. but now after I replaced the spark plugs and wiring I can't get it to idle easy or when I press on the accel. it dies.... any thoughts and help would be great.
Stilllearnin...
Old Jul 15, 2008 | 02:06 PM
Default RE: 1979 Camaro HELP!
If you're getting black crusty oil build up on the plugs, it's an oil issue...worn valve guides and/or rings.
But if the plugs had more of a black soot instead of crusty crap, then it's a rich carb.
For your running problem, double check your plug wires against the firing order. You could have accidentally crossed a couple of wires when you changed them. Firing order 1-8-4-3-6-5-7-2 should be cast onto the intake manifold, and the distributor rotates clockwise.
Old Jul 15, 2008 | 02:20 PM
Thanks for the reply and I checked it does have that cast into the block. I also thought maybe I had the choke high or something could that be the problem too? When I pulled those plugs they were black and a little wet and I think I have the wires on in the correct firing order, is there something I can check it against??
Scott
Old Jul 15, 2008 | 04:13 PM
When you changed the wires, did you do one at a time or all at once? They can be in the correct firing order, but off by one terminal on the dist. cap.
79z28camaro
Jul 5, 2010 10:38 PM
abel.towle
Nov 7, 2006 03:04 PM
Dietz589
Apr 5, 2006 12:35 AM
Dietz589
Feb 2, 2006 12:21 AM
Godfather
Nov 16, 2005 12:22 PM
