General Racing/Tech General talk about Racing or help setting up your car
NOS OCTANE BOOSTER?, Does it work, and will it harm my engine
Old Mar 11, 2007 | 07:21 PM
DOWS1997RS's Avatar
Default NOS OCTANE BOOSTER?, Does it work, and will it harm my engine
will it mess up my car?
Old Mar 11, 2007 | 07:26 PM
bluovlh8er's Avatar
Default RE: NOS OCTANE BOOSTER?, Does it work, and will it harm my engine
dont bother. actually if you have a reg. ignition or stock comp. you should only run 91 tops...
Old Mar 11, 2007 | 07:31 PM
coprunr's Avatar
read the back of the bottle, most say they contain no lead. it won't hurt your car if it has no lead, but it won't help much either. i have seen dyno test with different octane levels of fuel, and a low compression engine (10:1 or lower) can actually make more power with a lower octane because the fuel burns faster. high octane fuel burns slower than low octane fuel therefor reducing detonation.using a higher octane fuel than is needed in yourcar also lead to carbon build up.
Old Mar 11, 2007 | 07:55 PM
JD1969's Avatar
You don't have enough compression to need more than 91 octane, unless you are spraying the car or have a blower or turbo. Don't waist your money.
cjoelmitchell
Aug 31, 2009 03:37 AM
buddywackos
May 21, 2009 12:44 AM
SixShooterCamaro
May 1, 2009 02:53 AM
buckmaster
May 17, 2008 09:37 PM
giants4life07
Nov 13, 2007 12:38 AM
