Octane Booster?
Old Aug 29, 2009 | 05:24 PM
cjoelmitchell's Avatar
Default Octane Booster?
Can anyone recommend a good octane booster
Trying to troubleshoot engine ping and want to rule out low octane
Old Aug 29, 2009 | 10:15 PM
I know my Waldomart has it, Auto Zone probably does too.
Old Aug 29, 2009 | 10:29 PM
cbr600rx7's Avatar
Octane Booster will do nothing for you as it has been proven over and over again not to boost octane or boost it by a super small amount (LESS THEN 1 POINT) If you think bad gas is the issue go to a BP or Sunoco and fill up with 93 octane. If that does not fix your issue try adding some sea foam to the gas and air lines.
On a side note what kind of set up are you running? And is the gas because the car has been sitting or did you fill up in at a bad pump?
Old Aug 30, 2009 | 04:44 AM
clyon's Avatar
Whats wrong with octane boosters?
Old Aug 30, 2009 | 12:55 PM
They give you no benefit, if the engine doesn't require higher octane.
Old Aug 30, 2009 | 12:59 PM
Old Aug 30, 2009 | 05:59 PM
cbr600rx7's Avatar
As said above higher octane (fuels) dont have any affect unless the ecu is tuned for it by adding (boost, timing, ect) I am not sure on what set up you are running but if you are getting knock on any factory or near factory car it should not be from a lack of octane. You can go down and fill up with 93 octane and add a can of sea foam if you think bad fuel is the issue.
I do not recomend octane boosters for any one. I personaly think they are a waste of time and money if you want a higher octane fuel you can buy 1, 5, and 55 galon drums and have them sent to your door ranging from from un-leaded 101-113 to C16 .
Old Aug 30, 2009 | 09:51 PM
One more thing. If your knock sensor system is working properly, you shouldn't be hearing any engine ping. If the engine hasn't been modified to where it would affect timing, I would first look into the knock sensor, and related, as being a possible cause of the ping, not your gas.
Old Aug 31, 2009 | 03:37 AM
Thanks for all the feedback
How can I troubleshoot the knock sensor ? Is there only one sensor?
What about EGR valve?
Dealer is shrugging it off as no big deal, but I want it fixed
GLENN M
82-92 V8 Tech
Mar 1, 2011 02:25 AM
383Stro
Sep 29, 2010 12:08 AM
buddywackos
May 21, 2009 12:44 AM
DOWS1997RS
General Racing/Tech
Mar 11, 2007 07:55 PM
bowtieguy
Feb 4, 2007 02:49 PM
