General Racing/Tech General talk about Racing or help setting up your car
Hold up question.
Old Feb 21, 2008 | 10:33 AM
cbr600rx7's Avatar
Default Hold up question.
With the new project under way i can say she has gone a little out of hand. The new set now sports a FMIC, injecters, dyno tuning,the cats are now gone .and upgraded fuel pump. Power numbers should be around 450 groundhorse's and 500 torque on low boost and maybe a little bit more at the track. Right now i am sporting a set of 275 proxes i might soon switch out to some good old 555r's. Any way what kind of power and breaking isues am i going to run into. My trany has been sound for its 100,000 life spand but i already have plans for when she finaly goes. But what other isues do you guys think i will run in to.
Old Feb 21, 2008 | 10:38 AM
SpecterGT260's Avatar
Ninja Administrator
Default RE: Hold up question.
ur doing an STS kit on ur trans am correct? ur rear end is going to be the major problem, and your motor will go pop if u are still at the stock high compression and you try to run too much boost. other than that the tranny should be fine at 450rwhp.
Old Feb 21, 2008 | 04:50 PM
cbr600rx7's Avatar
Thanks for the input but this is on low boost. And i do mean low for a intercooled set up. The LS1 should hold up fine. My big problem i thinkand like yousaidis going to be with traction and the rear. Dont worry i am not going boost happy with this one and keeping the boost levels and tuning well on the safe side or at least till i can upgrade to my 402 .
Here is a question right now i am running nothing more then springs and upgraded sway bars on the proxe 275s. Traction has not been a isue in the past. Now with the new found power i am a little worried about my 60' times. I am thinking about swaping out to 555R's but dont want to put too much extra strain on the rear. Any input [>:]
I should have new pics up in the next 2 to 3 weeks of the finished product and the final numbers. WISH US LUCK.
Old Feb 21, 2008 | 05:25 PM
Ninja Administrator
i said low boost because the ls1 is 10.5:1 CR stock, thats really high, you can only hope to go for about 6-8 psi tops before it doesnt matter how u tune, things are going to blow.
Old Feb 22, 2008 | 05:52 AM
cbr600rx7's Avatar
The most she will ever see on the 346 will be no more then 7 psi at the track. To reduce strain on the street she will be turned down to around 5 psi.
Old Feb 22, 2008 | 02:47 PM
95slvrZ28's Avatar
I'd make a suggestion of going with the MT ET Street Radial, they get better traction than the Nittos. A drag radial isn't as hard on the rear end as a full slick is, just be careful when launching it, don't be supprised if you grenade the rear-end. Have a couple thousand sitting aside for a 9" when it happens
Old Feb 22, 2008 | 03:34 PM
Ninja Administrator
the MT radials are a good tire, but i would say only use them at the track becaus they tend to wear out fast. thats the only reason I went with nittos. lie SLVR said, if u go with a full slick u can expect that rear to turd out in under 3 runs [&:], unless u launch like a panzy on it, but if ur not going to limit the tires, u might as well go with a lesser tire like a drag radial
DarkKnight
Nov 29, 2009 04:07 PM
Bblock
Feb 5, 2009 09:23 PM
jmike38L
Feb 28, 2008 11:48 AM
sleepinZZZ28
Mar 9, 2006 08:26 PM
