Yet another Engine question
I'm looking into getting a rebuild kit for my 350 and I was looking on Summit...and justsomany different ones to pick from.
What should I be looking for in a kit if I wanna get everything I need to get this done?
A complete rebuild.
Thanks!
A complete rebuild.
Thanks!
RE: Yet another Engine question
You looking to do a stock rebuild or hop it up a little? Before you buy anything you need to know what is going to need done, such as does the crank need turned, does the block need bored, planning on roller or flat tappit cam, rods need resized, heads need redone. When you talk about a complete rebuild there are alot of things to consider.
