Engine question plz help!
Old Apr 23, 2008 | 09:44 PM
ElementSkater's Avatar
Default Engine question plz help!
ok i need help finding a replacement for my 1994v6 although i also want more power. No i am not doing a LS1 or an LT1 swap. I want a more powerful v6. I am doing this for insurance reasons btw thank.
Old Apr 24, 2008 | 10:52 AM
02StanGT's Avatar
Default RE: Engine question plz help!
So, the money you save on insurance, will be used to spend money on your car... Kind of balances out. I'm not saying swap a V8 in there, but you do realize that if you do, your VIN reflects that you have a V6 right? I've never heard of an insurance company asking to check and make sure you have what engine you say you have. They would insure it as a V6... If you want more power from the 3.4 bolt-ons help a little. If you want, you can take the heads and intake manifold off of a FWD 3400 engine, to boost power. When you do this though, the compression ratio is increased quite a bit. If you don't want it so high, you can swap out some internals to lower it a bit. If you wantto read about it, try googling 3.4 top end swap. Try a search for cams and such also.
Old Apr 26, 2008 | 08:37 AM
typeomang's Avatar
I would start with a fresh shortblock and get some head work, then do the standard air intake and exhaust mods...SFC
1974z28
Jan 20, 2011 07:04 AM
Bwalker
70-81 V8 Tech
Sep 10, 2009 01:33 PM
NightWolf
Mar 28, 2009 09:27 AM
BigJake34452
82-92 V8 Tech
Feb 15, 2008 10:43 PM
Andross
Jan 18, 2007 02:20 PM
