Vortec Heads- Self Aligning Rocker Arms?
Old Dec 7, 2009 | 09:06 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default Vortec Heads- Self Aligning Rocker Arms?
Is there a way around using self aligning rocker arms with the Vortec heads? Can you use screw in studs with guide plates, then use conventional rocker arms?
Old Dec 7, 2009 | 09:52 PM
Yes you can, that's your way around it.
Old Dec 7, 2009 | 10:18 PM
August 2009 ROTM
That's what I thought, thanks!
Oh yeah, which style guide plates would I want to use with Patriot Performance Vortec heads, and aluminum roller rockers?
Old Dec 7, 2009 | 10:29 PM
August 2009 ROTM
Actually, it says it comes with screw in studs and guide plates, however when I emailed a Jegs tech, they said that the Patriot Performance vortec heads are designed to work with self aligning rocker arms. It seems to me that I can use my current aluminum roller rockers without any modification: http://www.jegs.com/i/Patriot-Perfor...ductId=1192214
Old Dec 8, 2009 | 12:07 AM
Perhaps the tech was thinking about the other Patriot Vortec heads that don't have guide plates? The use of guide plates overrides the reason why the regular Vortec heads need to have self aligning rocker arms; the wider pushrod openings in the head. Unless they have something set up differently, but I can't think of what it could be. To put your mind at ease, you could contact Patriot and see what they have to say.
To make sure I'm not nuts (about this anyway), I dug through my bookmarks and came up with this article: http://www.chevyhiperformance.com/ho...458/index.html
Old Dec 8, 2009 | 06:50 AM
August 2009 ROTM
See, I thought I was nuts too, lol. From the looks of it, these heads should require no modification to use my roller rockers. The article recommends elongating the push rod holes when using 1.6 rockers however.
Thanks a ton!
76flh72xl
Jun 19, 2011 11:05 PM
sysanalyst
Mar 10, 2011 01:08 PM
marten
Mar 8, 2011 09:19 AM
Crunchy
Mar 28, 2010 08:45 AM
pyrofire127
Mar 17, 2008 01:48 PM
