v6 engine swap
Old Apr 28, 2007 | 01:09 PM
camaro98guy's Avatar
Default v6 engine swap
hi im new here and i need a little info. ok i got a 98 camaro v6 and that motor is going down the road and shes geting a big one. and my question is will a vortec 6.0L out of a truck fit in the car without major modifications.
also what is the trick to pulling the v6 motor and tranny out as one peice because i cant seem to pull that one off??
thx josh
Old Apr 28, 2007 | 02:37 PM
badinfluenceRS's Avatar
Default RE: v6 engine swap
it wont go in easy, I've actually seen a big Vortec in a original V6 car
It's not easy
Old Apr 29, 2007 | 02:12 PM
ok then is there any v8 motor that is a fairly easy project but will still push out big horse?? say 400+ hp it could be fuel injected or carb dont really matter. fuel injected is slightly preferable. but not by much.
thx josh
oh and i did get the motor out it wasnt much fun but its out.
Old Apr 29, 2007 | 02:27 PM
a 98 was meant to have a LS1, but an LT1 would work
Nothing is easy, best to find a donor car or it will nickel/dime you to death
Old Apr 30, 2007 | 11:27 PM
by chance does an LS2 engine come close to fitting anywhere likethe lt1or ls1 do or are they completely different????????
Old May 1, 2007 | 12:08 AM
I BELIEVE it is the same block as the LS1
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
