Stroked....
Old Oct 30, 2005 | 07:41 PM
Adam's Avatar
Default Stroked....
Ok, building my engine for my 68 project. Top end states it will add 225 hp, also stroking the 350 to a 383, other than increasing torque, what can I expect power wise from the stroke.???
Old Nov 2, 2005 | 12:42 PM
Default RE: Stroked....
Rough guess, 25-35HP, depending on what the rest of the engine is like.
Old Nov 2, 2005 | 09:58 PM
TimmyTheWop89's Avatar
that sounds about accurate, i also have a 383 stoker
Old Apr 5, 2006 | 12:38 AM
shnormo's Avatar
I got a high end stroker. It's putting out 517 HP and 562 FT lbs of torque at the flywheel. Milan International Speedway had Livernois Motorsport dyno my engine. So if you build it up with a High compression pistons, some head work, high lift cam, high ratio rocker, windage tray, stud gridles, 4 bolt main, K&N, dual plane intake, 850 CFM Edelbrock Carb, Holly Black fuel pump. ETC.
Fire Chief
Apr 10, 2013 08:28 PM
dbw47
Sep 21, 2010 06:36 PM
rondavis
Aug 20, 2008 08:15 AM
383blaze
82-92 V8 Tech
Mar 21, 2008 03:10 PM
