Recommended ATF fluid?
Old Jun 11, 2007 | 06:48 PM
Interceptor1's Avatar
Default Recommended ATF fluid?
I am going to servicethe autotranny on my '96 Z28 this week. I will replace the filter and fluid and wanted to hear any positive comments or recommendations from you guys as to what is a good quality ATF fluid to use, what works best in our transmissions.
My car has 64k miles, its my daily driver and I put about 250 easy miles every month. Thanks for your help!
Old Jun 11, 2007 | 07:16 PM
Default RE: Recommended ATF fluid?
If he transmission is stock, it will do fine with factory recommended stuff "DEXTRON III or IV", or some synthetic equivalent. I like to use the DELCO brand, because that was the factory fill, but other brands should also do the job.
Old Jun 11, 2007 | 08:34 PM
Thanks for your prompt reply Pete, and yes, my tranny is stock. I'll try to check out the Delco brand; I forgot to mention that I live in FL, so freezing temperatures are not an issue. What is better between Dextron III and IV? better detergent propertiesand/or shear resistance... basicallydifferent additives on a common base or are they different products altogether?
Old Jun 11, 2007 | 09:18 PM
DEXRTRON IV is the latest version, and is backwards compatible. I really don't know what the difference is, but is required for late model GM transmissions.
libertyforall1776
Mar 12, 2014 09:53 PM
sdotbailey
Oct 26, 2013 09:26 PM
jshwllngtn-91
70-81 Transmission & Differential
Mar 1, 2012 07:59 PM
andrewan
Apr 25, 2011 03:35 PM
ZZ04
Mar 16, 2011 04:42 PM
