Piston Rod Question
Old 03-24-2007, 01:06 AM
machineman's Avatar
Default RE: Piston Rod Question
ORIGINAL: GRIFF
On the stock rods if you just used the factory bolts what ballpark power could they handle? To change the stock bolts to arp they need to be pressed would you normally need to resize the rods?
I would say thatstock bolts can handle about 400HP. When installing ARP bolts, the rods MUST be resized. You would be really stunned to know how much changing any fastener from one tensile strength to another will affect housing bore size. We also use the stretch method as it is far more accurate. We chamfer all the bolt hole openings on the rod and the cap and we bore out the bolt holes in the cap just enoughtto make the rod slide over the bolts. Many times they are extremely tight and I can tell you that affects the sizes too.
cdnturboz
07-25-2012 01:32 PM
DarlingReject
05-19-2010 10:00 PM
cam1968327
01-27-2010 10:09 PM
Eric89RS
09-22-2007 04:01 PM
vampyrico
04-25-2007 03:16 AM
Quick Reply: Piston Rod Question
