LT1 no compression.. help
do u want a pair i got them need to be machined but i throw comp behive spring in for 200 bucks brand new spring
heads need milled but i have recipt showing that they are good no cracks or anything
so an overall: it ended up being that my heads were warped out pretty good(0.020") and the one was detonated in two places, and the head gaskets were completely destroyed.. so bad that compression was able to pass between all of the cylinders on the passenger bank. but the bottom end is completely fine yay!! I got the heads milled, I lapped in all of the valves and that turned out great(good seats).. and the head that was detonated I got welded and machined, you can't even tell that it was ever messed up. I got the heads on today. check out the pics
http://i721.photobucket.com/albums/w...1fixedhead.jpg
1994, 76nova, 94, camaro, chevy, compression, compretion, couls, engine, gasket, head, interference, lost, lt1, pic, replacement
