LT1 no compression.. help
Old Oct 7, 2010 | 12:33 AM
NEVERLETITDIE's Avatar
do u want a pair i got them need to be machined but i throw comp behive spring in for 200 bucks brand new spring
heads need milled but i have recipt showing that they are good no cracks or anything
Old Oct 7, 2010 | 03:18 AM
kaymoto's Avatar
I'm not sure yet, I'll know tomorrow if the head will be salvageable. if so I'll probably just gasket match and polish em. I'll let ya know tho
Old Oct 7, 2010 | 06:30 AM
have you turned it over to make sure the pistons are all moving. if only one side head is bad why did both sides have pistons with 0 compression. its not adding up.
Old Oct 28, 2010 | 05:38 AM
kaymoto's Avatar
so an overall: it ended up being that my heads were warped out pretty good(0.020") and the one was detonated in two places, and the head gaskets were completely destroyed.. so bad that compression was able to pass between all of the cylinders on the passenger bank. but the bottom end is completely fine yay!! I got the heads milled, I lapped in all of the valves and that turned out great(good seats).. and the head that was detonated I got welded and machined, you can't even tell that it was ever messed up. I got the heads on today. check out the pics
http://i721.photobucket.com/albums/w...1fixedhead.jpgName:  lt1fixedhead.jpg
NorthernCrew454
Oct 17, 2011 09:30 AM
BasicConcepts
Sep 11, 2010 03:14 PM
BasicConcepts
May 7, 2010 06:43 PM
z-28foxx
Feb 10, 2010 11:33 PM
Bennyt900
Jun 1, 2007 10:22 AM
