ignition help please
Old Jan 29, 2008 | 07:17 AM
scottlee1's Avatar
Default ignition help please
i have a 69-396 with HEI. The #2 & #7 cylinders are not firing regularly. It first started with the #7 plug, but went away after a wire change. i thought prob cured. but now the # 7 fires intermitantly and the #2 not at all. i thought new wires again, but no help. if i pull the wire off of the cap, the dist can fire 1/2" to hit my finger or the pug end, so know dist is firing. i dont understand what is causing the intermitant or the lack of firing. Please email direct if possible.
Any help please
Scott
slee@bellcrest.com
Old Jan 29, 2008 | 10:01 AM
Default RE: ignition help please
Have you looked at the plugs? The may be bad or fouled becuse of the previous bad wires.
Chevynutz
Jan 22, 2012 07:52 PM
dogdog130
Sep 11, 2011 01:12 PM
93camaroz28
Jan 8, 2008 10:58 PM
1994z28
Dec 6, 2007 03:48 PM
carguylt1
Mar 22, 2007 09:47 PM
