hypereutectic pistons- good or bad
Old Aug 23, 2007 | 08:16 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default hypereutectic pistons- good or bad
i hear everyone say that theyre crap, but none of them have ever had any real experience with them. my plans are for a mild 350 tpi, a cam with .440 exhaust lift with a 1.5 rocker, bigger throttle body, headers, bigger injectors, possibly port polish and port matching, race muffler for a cat (no emissions required), and maybe a 100 shot of nitrous in the distant future. only looking to make about 325 hp and run low 14's, high 13's with the 2.73 posi rear (ran 15.2 with the 305)
Old Aug 24, 2007 | 07:57 PM
Default RE: hypereutectic pistons- good or bad
Stronger but more brittle thancast aluminum, but not as strong asforged. Used as OEM on many cars.
Old Aug 26, 2007 | 10:21 AM
blackz87's Avatar
With your plans they will not be any problems. Higher Horsepower setups are using that type of piston.
Old Aug 29, 2007 | 06:04 PM
LT1RUNNER's Avatar
I have a friend who races on a circle track and he recomended them and he says he uses them all the time.
Old Aug 29, 2007 | 09:28 PM
riceeater's Avatar
they are good to a point, I would not spray more than a 175 shot on them, and I would not go over 475 -500 overall on them, dont want to constantly turn high rpms with them
Old Aug 30, 2007 | 11:14 AM
microkid's Avatar
March 2011 ROTM
Technical User
i had a teacher who built engines for 35+ years, and said that they would be ok up to a 250 shot if you did everything correctly, and only used the nitrous when you are supposed to (at wot), unlike kids who punch it as they leave the line. i dont plan on making more than 350 hp or spin more than 5k rpms max, so i should be ok
Old Sep 9, 2007 | 07:21 PM
Marroweter's Avatar
The nice thing about hypereutectic pistons is that they don't expand as much as forged aluminium ones do, so you can run tighter clearances.
Old Sep 11, 2007 | 09:47 AM
riceeater's Avatar
yeah, they may be ok in some instances to a 250 shot, but I wouldnot chance that at all, id def stay below 200
84-z28-305
Oct 15, 2012 10:46 AM
mapes7
82-92 V8 Tech
Dec 10, 2010 04:36 AM
1998camarossclone
Feb 3, 2010 12:14 PM
NYH1
Aug 21, 2009 12:27 AM
Deviousz28
Mar 2, 2009 09:31 AM
